Hello All,
I am following the instructions given in the #1 for setting up WidevineProxy2. I tried to create my own .wvd file by following instructions given in https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio. I was hitting below errors while running dump_keys.py
2024-11-30 01:29:44 PM - Helpers.Scanner - 85 - ERROR - unable to process the message
2024-11-30 01:29:44 PM - Helpers.Scanner - 86 - ERROR - {'type': 'error', 'description': 'Error: access violation accessing 0x3', 'stack': 'Error: access violation accessing 0x3\n at <anonymous> (frida/runtime/core.js:145)\n at readStdString (/script1.js:316)\n at onLeave (/script1.js:361)', 'fileName': 'frida/runtime/core.js', 'lineNumber': 145, 'columnNumber': 1}
2024-11-30 01:29:44 PM - Helpers.Scanner - 87 - ERROR - None
So I put that in hold and I am now using one of the Ready to use CDM given in https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21. With that I am seeing "Device Not Supported" error from browser. I am seeing this on both chrome and firefox. attached the screenshot of the error. Please help
Results 181 to 210 of 731
Tried getting something from ABC today and WVP2 doesn't even seem to see the stream.
I managed to get everything without it, but my first attempts didn't decrypt properly and new attempts result in Forbidden (403) errors. Tried adding headers and such, but it doesn't help, but the stream is still playable on the link for me.
https://abc.com/movies-and-specials/eef05664-2179-46e3-b95d-dd9963a7dae1
Code:https://content-dtci.uplynk.com/ext/d874124ecca24c88a3c9575e78686acf/9c6d811426a441b59b9a0b35bbe7e9da.mpd?cqs=CXEWB8mKAOGWzBh4rFFXo6whINxAL6-_XcpAtlBiyJ5icGdrFLogGNXrlkInl271xM1vw5N8z2FSjpwm0w3-l1_ywcLWxHqvIUtCmLlposCDXkykNlw_yWLv4pKw52z4KqwDnCKJuMmn-yhAY2DssRfBfKk3o5Ovn-urQo4C4v5iQy16ozX5vwXLc9TToE-il3VGBYxBPmTWkgZchKfhUMD5XgavD8082R7I3sW8wXnJ0pxOGhGeQdBFfHZfeFvwBfotGW7950Ignd_urABYqHDbMr-vstWtvp5tFxUB7Co2Q5fJAJmoRRqLgku4lVia-gb94hbGXwD6QaVE9d6rIYfBmESFOK4ZyGKlsQ-hao-vo1MSa6QRdff3-Zm6Fg5adT8rTzA1RhqjdFvmdQAzoXPjDV3sTXiUZVSQjA6jOITXweKO0g8_s0c9JOkO72g-moidB_mdPB1LmbtX4yVEAH3XC5D60E7sJp61o7nQEcfLDd7M6_DBS2BKrbYAShkSySRCaS5_WJGQ60aShqsGRHK0tIEdG15_b3DaGPR_z-iq1IU13ho3cLF_HDrqzNeBv7Rz8f1gD9048spqBV5frA==&kid=4098a6a720374bfcbb4e362b652bcd51
Please don't just give me updated codes, that's not why I'm trying to learn (at least this one). Does this need L1 is why I can't get any of this to work?Code:cc04c20544d34e28995694055e872f05:39a87a68f4ce1e4d300d4e557897cd79
I would think WVP2 would see this anyway.Last edited by doctorm; 2nd Dec 2024 at 13:50.
I just copy pssh from mpd (there is 2 wv pssh so you will need 2 keys)
lic url (filter "wv") https://content-ause1-ur-dtci2.uplynk.com/wv?b=6883dda7e18049d28e7f80508f22347f&v=6883...24c630c3f0db60
result...
Code:--key 4ef34e65f75343b3be31e0127c6d1855:77b00b4bf2b8a027f64c0b2f75213388 --key cc04c20544d34e28995694055e872f05:39a87a68f4ce1e4d300d4e557897cd79
Thanks. Ridiculously I looked for a second key and didn't see that those KIDs were different for just a few characters in the middle. I thought it was a duplicate so I ignored it.
Still wonder why WVP2 doesn't seem to get this one. -
i have some issues.
a service i am trying to use is blocking the video as soon as i switch the addon to Enabled. Anyone had the same issue? -
That behaviour is documented in bold letters in @larley's explanation in the start post in the "Usage" section.
As a noob to this, and the various apps needed, just to say thanks. Past couple of days been struggling (and failing) with various software to rip a few episodes I wanted, then read through this thread, obviously struggled a bit - but perseverance paid off, now successfully ripped those episodes I needed.
Thanks to all involved, cheers.
Is there a trick to getting this to work if the video plays in an embedded player on the page, because there is one site that I just can't get this to work on because it plays in an embedded player.
This is the site...
https://www.fox10phoenix.com/
and I am talking about the live feed that plays in the window. -
use the browser add-on called the stream detector, - https://www.videohelp.com/software/The-Stream-Detector once installed select N_m3u8-DL-RE
from the drop down menu and select the m3u8 live stream to download. -
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Edit: Resolved! VPN issue.
Anyone help a noob out with what may be the problem here please?
When executing the given N_m3u8DL-RE command - output (have xxx'd out the url, I think that's in accordance with forum rules), and screenshot below. Running in Admin command prompt. Using the extension in up to date Brave browser. Firewall is temporarily disabled, also tried with VPN disabled.
Whether relevant I don't know, but this exact same setup has successfully ripped a few episodes of a TV show.
Code:13:39:06.272 INFO : N_m3u8DL-RE (Beta version) 20241203 13:39:06.279 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:06.401 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (1/10) 13:39:07.904 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:07.905 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (2/10) 13:39:09.411 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:09.413 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (3/10) 13:39:10.919 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:10.920 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (4/10) 13:39:12.425 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:12.427 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (5/10) 13:39:13.931 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:13.932 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (6/10) 13:39:15.437 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:15.439 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (7/10) 13:39:16.943 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:16.945 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (8/10) 13:39:18.449 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:18.451 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (9/10) 13:39:19.958 INFO : Loading URL: https://g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com/pub/global/PYH/Q6Y/PCK_1625015543377.762_01/cmaf/mpeg_cenc/master_cmaf.mpd?c3.ri=8890797437463169391 13:39:19.960 WARN : An attempt was made to access a socket in a way forbidden by its access permissions. (g003-vod-us-cmaf-prd-qw.cdn.xxxxxxxxx.com:443) (10/10) 13:39:21.467 ERROR: Failed to execute action after 10 retries.
Delete this post please.
... application_name com.vdocipher.zenplayer origin N package_certificate_hash_bytes ,LNL5eZ9Hk6W4WR6+kYof2lmdJh6igzcZ6B44OKn1lVY= ... widevine_cdm_version 16.1.1@006 $ oem_crypto_security_patch_level 0 L oem_crypto_build_information ,OEMCrypto Level1 code with V16 on 2021/10/282 ( 0 @ H H P X ` Z X 2
Trying to download from vu*d I only get 480p resolution... and this error shown in the screenshots... Any idea?
[Attachment 84141 - Click to enlarge]
[Attachment 84142 - Click to enlarge] -
add header -H
like referer, origin, cookie. however without video link for test your question will remain unsolved -
It's a rented movie... and expires in 4 hours
Link is https://athome.fandango.com/content/movies/play/3769979/PURCHASED_CONTENT?returnUrl=%2...or%252F3769979 -
Does this tool work on Netflix? I have L1 CDM, which works on Prime Video and Peacock but doesn't work on Netflix
[Attachment 84157 - Click to enlarge]Last edited by doughnuts; 15th Dec 2024 at 14:05. Reason: image added
on paramount+ germany it doenst work anymore, last week it works.
with widewine fetch
License Response:
b'{"code":190120,"message":"No keys were added to the license response. The clients\' platform status (noVerification) is restricted, the configured policies prevent the return of a license."}'Last edited by bordellmaster007; 17th Dec 2024 at 13:56.
Thanks for a great extension, save alot of hustle!
works fine on most sites.
but I stumbled on an issue.
it wont start the stream, and when checking, the license request had
400 Bad Request- {errorCode: "OVP_00114", description: "Unsupported browser/client"}
- description: "Unsupported browser/client"
- errorCode: "OVP_00114"
The site workes fine if the addon is disabled, but as soon as i enable it, i got this.
using a local .wvd - {errorCode: "OVP_00114", description: "Unsupported browser/client"}
Peacock TV? It's your CDM. They've recently started blocking emulated CDMs, so you'll need to get one from a real device.
https://forum.videohelp.com/threads/403049-Steps-for-Peacock-TV/page4#post2743671 -
Please is there any Fix/workaround for VDOCIPHER ? it show error "open in android app"
[Release] WidevineFetch - Keys from just the License URL; Any Lic. Wrapping
By larley in forum Video Streaming DownloadingReplies: 263Last Post: 20th Nov 2025, 01:49 -
[Release] Widevine L3 Guesser Extension-Works in 2024 Firefox/Chrome All OS
By FoxRefire in forum Video Streaming DownloadingReplies: 795Last Post: 15th Oct 2025, 11:19 -
MY5:- HMAC and AES: NO BROWSER REQUIRED Stand-alone script.
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 10Last Post: 22nd May 2024, 10:18 -
Lic with jsondata
By sangoku in forum Video Streaming DownloadingReplies: 3Last Post: 21st Feb 2022, 15:02 -
help decrypting drm dash hmac
By filipino in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2021, 06:07
